DionR
Looks good!
Did you end up getting that 6.1 intake?
Looks good!
I just installed the Corbeau LG1 (W) with brackets using the stock lap and shoulder belts in the Duster before autocross school March 30th. I love these seats. No more being tossed against the door cards and holding on to the steering wheel!
View attachment 1716233907View attachment 1716233908View attachment 1716233911View attachment 1716233912View attachment 1716233913View attachment 1716233914View attachment 1716233915
very nice, you're going to love it!
I see you have the Holley pan. @HemiDenny has been anxiously waiting to find out if it clears his K-member. Did you have to modify anything to make it work? Before I installed my K, I kind of mocked it up on the engine while it was on the stand and it looked like it would be fine.Got fuel lines buttoned up, power steering lines done, and got a plan for throttle pedal. Going to modify the factory pedal to accept the LS cable attachment. Also got hydraulic clutch bled and working great. Sure is nice to sit in the drivers seat a pump the clutch and shift through the gear box.
You can see the bracket I made off the brake MC here as well.
Thank you!
I’m on the hunt for a radiator and electric fan suggestion at the moment.
Not sure If I need an oil cooler but don’t think I do.?
Holley pan next to a Jegs pan which I believe is the same size as the Milodon panI see you have the Holley pan. @HemiDenny has been anxiously waiting to find out if it clears his K-member. Did you have to modify anything to make it work? Before I installed my K, I kind of mocked it up on the engine while it was on the stand and it looked like it would be fine.
I don't recall if Denny's concern was the height, or the sump location. Picture above looks very close to the steering rack. However, eelier in his thread he mentioned the engine was as far forward as he can go (Denny's mounts are adjustable). I plant to put mine as far back as possible.Holley pan next to a Jegs pan which I believe is the same size as the Milodon pan
View attachment 1716237368View attachment 1716237369View attachment 1716237371View attachment 1716237372
Push'm back, push'm back, way back!I don't recall if Denny's concern was the height, or the sump location. Picture above looks very close to the steering rack. However, eelier in his thread he mentioned the engine was as far forward as he can go (Denny's mounts are adjustable). I plant to put mine as far back as possible.
I have my engine as far back as possible. Tight enough that I can't run the factory SRV module on the back of the SRT8 intake, had to run the MMX block off plate. With the engine this far back, it BARELY clears the power rack and pinion, like 1/8" clearance.... No other interference other than that possible one. I had to machine some OD off the steering shaft though to clear the TTI headers. You could also machine the spacers on the R&P to move it forward a little bit which would help with steering shaft/header clearance.I see you have the Holley pan. @HemiDenny has been anxiously waiting to find out if it clears his K-member. Did you have to modify anything to make it work? Before I installed my K, I kind of mocked it up on the engine while it was on the stand and it looked like it would be fine.
The Milodon looks like it would clear no problem.Holley pan next to a Jegs pan which I believe is the same size as the Milodon pan
I pulled a complete setup out a 2013 (?) Charger V6 police car.. I believe they're all the same. Cheap and plentiful, even if you buy new. Butchered the stock lower mount to just bolt in and fab'd some upper brackets, utilizing the stock rubber inserts. Really happy with how it came out, considering I have $50 in the whole thing. You do have to roll the frame rail lip down on pass side for clearance.. same lip that interferes with the alternator.Thank you!
SRT8CUDA Build110% jinxed myself.
Got throttle cable installed on pedal side, I ran the attachment a little higher than factory to try and get more travel out of it. But factory pedal travel only opens the LS cable throttle body maybe 50%.
With the extra travel needed I dont know that modifying the pedal linkage itself would be enough. I might have to work something on the throttle body side. Either a secondary lever that compounds the cable travel, or a smaller cam on the throttle body itself. Pedal travel I’m guessing is about 1.5-1.7” and the throttle body needs close to 3”….
Gonna think on this one! Any ideas?
Mike
