brake adjuster rotation?
usdart
West Richland, Wa
Which way do you turn the Star Adjusters for driver and passenger sides to release them from the drum.:eek:ops:
I am going to replace my Shoes next week and I know how hard they are to get off so I want to plan ahead and ask stupid quetions. These simple things tend to cost me money later if I don't ask.
1973 Dart Swinger, /6 automatic car.
Car NOT for sale, this is from when I bought it.
Frankly I've never bothered to learn this. Anytime I've done a brake job, and I've done many in my lifetime, I just wiggle one drum loose, and turn the adjuster one way or the other. It won't take more than 4 or 5 strokes, if that, to tell
On some self adjusters, you can not even turn them "loose" without getting in there with a wire hook/ etc to pull the ratchet away from the star wheel.
You have a shop manual? See below:
http://www.forabodiesonly.com/mopar/showthread.php?t=132309&highlight=click+save
Use small screwdriver (or welding wire)to push adjusting lever off star wheel.
Apply adjuster tool to star wheel and move the tool down to loosen brakes.
IE:
Toward ground to loosen brakes.
Toward sky to tighten brakes.
IE:
in case someone skims this without thinking about it (as i've been stupid enough to do when i'm in a hurry :tard:), that's for doing it from the rear access on the backing plate with the drum on the car
