Is this a good deal?
Valvebounce
Christchurch New Zealand
I came accross this http://www.trademe.co.nz/motors/car-parts-accessories/chrysler/gear-boxes/auction-423477969.htm while surfing tonight.
I did a google, but I've not been able to find what's included. I'm guessing it's seals and gaskest? I scored a 904 in bits for $20 (Was alegedly a good box prior to being dismantled) So this might be a good thing to have. Other thing is, I'm on the other side of the world from you fullas, so anything you can buy, add at least $20 for postage. Plus our dollar is worth a bit less than the green back.
I wouldn't buy any automatic transmission parts with rust on them. If it has enough extra parts inside that aren't rusty, it might be good for spares but I'd just buy a good rebuild kit if it were me. That way you know you have everything and it's fresh.
I agree with Mark. No matter how cheap it is it's useless with rusty parts. Plus it's not even a rebuild kit, just a basic seal kit. It doesn't have seals, clutch discs and steels, bushings, bands, a filter, or a rear sprague roller and spring kit.
X3. When you start with junk parts you will end up with junk. Automatic transmissions are not very forgiving and too much work to pull so buy fresh stock good quality parts.
