We are at about 1000 ft.
There is a DCR calculator that takes elevation into account. 1000 ft up should help. I believe.We are at about 1000 ft.
My static on new engine is 10.18 but dynamic will be 8.8-8.9, BUT I have magnum heads and a cam at 251-260 @50
Ok, so what's different about Magnum heads? Are they more efficient as far as detonation somehow?
Whats the intake closeing point on that cam?
StrokerScamp said:Ok, so what's different about Magnum heads? Are they more efficient as far as detonation somehow?
dodge freak said:You know, just cause you might not hear the motor knocking, doesn't mean it isn't
Forged pistons can withstand some abuse
I got a feeling those with high compression and 91 octane gas also have a very loud exhaust. Muffler it down so you can lightly speak and be heard and then see if you can't hear the motor rattling at times
- Location: St. Helens OregonYes, if it has a loose converter and 3.91 or better gear. All day long.
- Location: Fair Oaks Ca,I run over 11.1 on pump gas! iron headed 360, at sea level in the heat no problem and i only get 91 octane california crap fuel.
I am just going by what others are telling me and what engine builders like MRL and IMM have told me. You do not need to listen to me, my car is also in Ca at Sea Level. I had Kb107 at 0 deck which was actually 10.9 with 62-63cc magnum heads and a xe274.[/QUOTE
My 360 has 10.6:1 static compression and cranks 195-205 psi and runs fine on 89 octane. I have tried 87 but I need to be careful. even on 100+ degree days it runs fine on 89.
The key to this high compression on iron heads is a tight quench. The magnum heads I am using ate closed chamber and the pistons are at zero deck, with the .039 thick head gasket I have an
Ideal quench that makes the engine very detonation resistant.
Note: good cylinder turbulence requires less timing. I run 33 with it all in at 2500 rpm. Initial timing is 17.
My 360 has 10.6:1 static compression and cranks 195-205 psi and runs fine on 89 octane. I have tried 87 but I need to be careful. even on 100+ degree days it runs fine on 89. - Location: Pembroke, MA
They are a closed chamber design, that is, the chamber in the head is not as big as the cylinder bore so a portion of the deck surface of the head protrudes over the bore. When combined with a flat top piston that comes up flush to the deck surface of the block it is the thickness of the head gasket that keeps the piston from contacting the cylinder head. If this gap is maintained in the .035-.045" range the mixture in the cylinder will be very violently squeezed over to the other side of the cylinder creating a very uniform mix of fuel and air. The uniform mixture eliminates hot spots that cause detonation. Virtually every current engine design uses this principle and it allows for higher compression without detonation.
I ran 11:1 on pump gas and iron heads, with 4.10s, and, yeah, I had to back off the timing (a lot) to keep the detonation at a point where I didn't cringe (too much) when I hit it.Sure it will run. I am at 11+ with iron heads. I can rumble through town if I keep the load off.
But it's really kind of pointless. You will have all this power that you can't use. Hell, a Geo Metro would probably beat you in a drag race, at least it won't be in chronic detonation when hammering on it, like you would be.
The people claiming higher compression useage near the ocean do not have Houston heat or constant humidity. California, Oregon, and Maine do not have Houston humidity. (Even the Oregon rains are not the same...the heat in Houston slaps you in the face immediately after sunrise with instant sauna in June, July, August, and September.
Im in san jose and no we do not havw 100% humidity, but we have close to it with 65-75% not like So Cal.
But the only drag race I ever lost was a half-length to a built 350 with a 150 shot of nitrous (and, in his words, "I was on the button hard")![]()
