streetdak
I just got my 360 out of my Grand Cherokee donor running independent of the vehicle so im stoaked! ready to slap it in the Swinger, but need to know some info first.
First question, im most likely going to have to use my 904 from my 318 for a while. I have a 3k converter in it now, I know I have to get balance weights welded on the converter because of the external balance of the 360, but will it bolt up to the 360? Or do I need to change the flywheel?
2nd, what PSI fuel pump do I need to run and do I need to run a regulator inline, or is there a built in regulator in the fuel line on the magnum motor?
thanks for any and all help!
