9 inch Front Drums on my 1971 Dodge dart
Mopar King
Beginner / Need of Help
New York
I know this is a dumb question but I have to ask you guys out for a little help. Also if I'm using the incorrect word terminology please correct me
I been looking on line and for some reason I can't seem to find a 9 inch front drums with the hub assembly anywhere. I ordered and got both the inner and outer 9 inch bearings from Autozone but when i ask about the 9 inch drum brakes they told me that they have been discontinued/out of stock.
I tried ordering one from summit but got the wrong set - They didn't have the hub to hold the bearings. I am also seeing in most auto store websites the pictures aren't clear and can't tell if its the drum with the hub. I got two other part numbers but descriptions are not too specific and the summit picture is showing a 4 bolt pattern (yes I read that the image is a representation and actual item may vary) but it still makes you think and doubt.
This is for a 1971 Dodge dart 4 door sedan - Slant six and small bolt pattern, All drums
http://www.classicindustries.com/mopar/parts/2956.html
http://www.summitracing.com/parts/axt-ax8190/applications/make/dodge/model/dart?prefilter=1
The hubs do not come with the drums. You reuse your hubs. If they have never been seperated before they will need seperated. There is a thread or two on how to do it.
I have a set of used drum to spindles just sitting in my back yard you can have. All we have to do is figure out how to get them to you. They came off my 70 dart. :burnout:
