71RALLYEDART
Are V8 and /6 4 speed bellhousings interchangable.
No and how I wish they were.
So a v8 bell housing can not be put on a /6 trans?
Nope.
Dang ok
Check out the pictures I just posted.
Yes. If the slant six transmission is a 4 speed (as many were) OR the V8 bellhousing has a dual bolt pattern, the V8 bellhousing most certainly CAN be bolted on a slant six transmission. Would you like some pictures? I HAVE a 4 speed OD that was behind a slant originally. I also have a V8 bellhousing that will bolt RIGHT to the transmission. I plan on putting it behind my 331 Hemi in my rat truck.
Look at post #6. He made it clear as a bell. Unless he made a mistake. Post #6 does not ask about the bellhousing to engine bolt pattern.
Dang ok
Ah ok. I see how you mean now. Sorry, I'm a visual aid kinda guy lol
I think you need to look because the op has only posted once in the entire thread. You could be correct but the op never said if it was engine, transmission, od tranny or anything else.
This is post #6.
You might want to check out post #8 if you are talking about MoparDaddy.
I've read the whole thread. 71RALLYEDART's question was answered incorrectly. That's what I was addressing.
I was not arrogant. I was simply adding to the conversation. I also did not post #6. That was someone else. Nowhere was I trying to be a smartass or be arrogant. Sorry if you took it that way. In MY post #11, I referred originally to post #6, but I made a mistake. I meant to refer to post #4. I went back and changed it. That's the post I was trying to give correct information to. #4. So I made a typo. I apologize. I'm not perfect, but this happens to be a subject I am familiar with since I am building two things using dual pattern bellhousings. I simply thought I would throw it in the mix. I'll stay out of it.
Exactly as I posted. IF it has the dual bolt pattern, it will. How bout pointing out the arrogant part? You keep insisting it's there. You talkin about me askin if he wanted pictures? I was bein stone cold dead serious. I have bellhousings and transmissions in the shop. I was offering to help. You're reading way too much into this.
I can't be anymore apologetic. I've apologized three times now. I know #4 wasn't the OP. I was merely adding to because it is possible to swap with the right bellhousings. As for caps, really? I was using them to stress words, not yell. Now, I've apologized more than enough for something I see no wrong in, but I still apologized for. But you still forge ahead unwilling to even think for one minute you might have taken something I said the wrong way. So whose being arrogant here? Tell you what. You stay on your side of the tracks and I'll stay on mine. If this is what I get for trying to help, it's not worth it.
I don't know what you're talkin about with the "split". I guess year models? If so, I don't know about that, but as I said earlier, I have lots of things to take pictures of. These first two are factory small block bellhousings. The top one is a dual pattern (3 and 4 speed) non overdrive bellhousing. I've had people tell me they didn't exist, Chrysler never made them. Well there one is. The bottom one is a standard OD bellhousing with the dual bolt pattern (3 and 4 speed). To my knowledge, all of the OD bellhousings were dual bolt pattern....I could be wrong about that.
The last picture is the slant six OD dual bolt pattern (3 and 4 speed). Although it is a high starter mount for a truck, they also made a dual pattern for the slant car. I have one under my 63 Dart. Chrysler of course also made dedicated 3 and 4 speed bellhousings, although I have never seen a dedicated 4 speed slant six bellhousing. All of those I've ever seen were dual bolt pattern. Of course, you might have to swap around the front bearing retainer in some cases. The OD bellhousings all had the 5.215" bearing retainer hole, but those are readily available.
There are six bearing retainers that I know of. 4.350, 4.80 and 5.125 both small and large bolt pattern, so there's no reason for people to make rings or adapters. I always wondered about that, myself. And yes, your wheel hub comparison is a good one. You must run the correct bearing retainer. The standard 3 speed (A230) and the 4 speed OD have the same bearing retainer bolt pattern, so the OD retainer is a direct bolt on to the A230 3 speed.....and vice versa if you don't have an OD bellhousing. I have an A230 I was considering running behind my Hemi, because I have the original big truck bellhousing that bolts directly to the Hemi and requires no adapter plate. It also has the same pattern to accept the A230, but it has a 5.125 (OD size) bearing retainer hole. I took the retainer off one of my OD transmissions and bolted it right on to the A230 and slapped it on the bellhousing and it fit perfectly. Correct depth and all. BUT, it's not a 4 speed and it's not an OD. Plus, I would have some fab time in the clutch linkage because the clutch fork is on the passenger's side and would require some fab work, whereas the 500 buck adapter plate will bolt the later 4 speed OD bellhousing right to the Hemi. It's a decision I am still thinking about.
