TrailBeast
AKA Mopars4us on Youtube
Factory Mopar four pin module with four pin GM HEI ignition module built into it.
All the factory pins are connected to the HEI unit inside the box, and it is a direct plugin to the factory harness.
This unit can be used with or without the ballast depending on coil used.
Plug this in and you have everything but the coil ready for HEI.
No new or different wiring needed.
A whole new meaning to my existing High Energy Ignition product. www.ClassicHEI.com
Currently only have one available. $125.00 shipped in the US.
Located in 86314 Arizona
First dibs gets it, and I'll give the Paypal or Money Order address via PM.
