wardy
Hey all, haven't posted on here yet but thought I'd share my latest project to break the ice
1968 ve valiant sedan.. Basic rundown.
360ci small block chrysler.
Basic rebuild with a decent set of pistons
Off the shelf hydro cam
Arp studs throughout
New water/high volume oil pump blah blah
650 double pumper modded myself
Extreme velocity carb hat
Mopar m1 manifold
044 pump and aeromotive reg
75mm gt42 60mm gate
eBay block huggers and custom turbo manifold 3.5-4" exhaust
Frontmount
9" diff with around 3.25 gears, 31 spline axles 904 auto, built, 3500 stall
Widened wheel tubs
Springs moved inline with chassis
CL/cm front brakes
Resprayed white
Reverse cowl scoop
Retrim interior to standard, bench seat and all (until it needs to go)
Pro stick shifter and a few guages
I'm sure there will be more along the way. Plan is to run a 275 radial and run 10s driving to and from the track.. 9's if all goes well Here's a few pics ranging from when I got it a month ago to now... Enjoy Wardy
Mopar m1 manifold
75mm gt42 60mm gate
Frontmount
Widened wheel tubs
CL/cm front brakes
Resprayed white
Reverse cowl scoop
