firechicken1992
Member
Doing what I thought would be a routine drum and shoe replacement on my girlfriends 64 Valiant. Got the springs and everything apart (using proper tools as well). Put on the new shoes with primary shoe facing forward on both. Greased the new bearings and drove in the new races (again with a proper tool). Greased the star adjuster threads and cable. Put the hubs on and tightened down the wheels. Both sides seems to catch only at one point on the drum. My friend who worked at Orielly's (where i bought the parts) said he has sen warped drums outta the box before. I took them in to get checked and sure enough they were warped. Got them turned and brought them back home. Still catching! I have checked and rechecked multiple times and I'm at a loss. Ive had much more experience with disc brakes over drums although i have still done drum work, and never have had this problem. Any suggestions out there? Its been 100 degrees the past couple days and I've been putting hours into this each day and I'm about to lose it :banghead:.
