Pawned
N.R.A. Lifetime Member - And damn proud of it
Debbie had just got home so I moved my Taurus so she could park in the garage, then went back to working on Natalie. Left the garage door open as I am working on Natalie most of the afternoon.
I am lying on my back with my feet out Natalie's drivers door. I am working on installing a fan switch in the middle of the dash board. All of a sudden I smell smoke or feel heat, I do not know which. I look around and the car is on fire. I had the steering wheel and a few papers on the floor in front of the passenger seat. The papers are burning. I grab the wheel and move it. I try to stomp out the fire with my hands. I grab the papers, the part that has not burnt yet and throw it out the window. I grab the inexpensive fire extinguisher the size of a can of pledge and pull the tab and the whole top comes off and will not work.
I got out of the car from the drivers door and go around the car and stomp out the papers that are still burning. The fire is now out. Luckily there was a heavy rubber floor mat so it did not damage the carpet.
I go over everything and find there is absolutely nothing there that can start a fire. There is only one possibility and I do not think it is feasible, is that someone walked into the garage and grabbed some paper, lit them and dropped them in the window. ............. I called Debbie out and she also could not see anything that would cause a fire.
I am now inside for the day and I disconnected the battery, took out the main fuse and closed the garage door.
I am a little shook up, not because of what happened, but because I can not understand how it happened. :banghead::banghead:
