Sounds like they used the BBP disks of 73+ cars. You can buy a setup new on ebay (pricey). You can swap spindles L & R, and some even use Aspen or B-body spindles. Probably one setup gives the most caster, which we need for radial tires. You want the upper ball joint as far aft from the lower ball joint (centers) as possible.
