Yeah it looks like the most you could get away with tire-wise is what will fit with a 1/2" spring offset. Probably would get you that much room changing the 2.5" wide springs out for the tubular links, and if not you might be able to cheat the links in a little with the spacers or even use the offset front hangers.
That's all that you can get on an A-body anyway without a mini-tub. Still works out to a 275 or maybe 285 on a Dart and a 295 on a Duster/Demon/Dart Sport. That's a decent amount of tire, I'm really impressed with the 295's on my Duster.
Seems like a decent deal if it sells for what they say it will. Guess I might have to find a tech that could tell me if it will indeed work if you've relocated the spring perches in a 1/2". Shouldn't really be a problem. Bigger issue than that would probably be the exhaust routing, looks like my exhaust would occupy the same space as those coilovers...
