Bakerlite
- Joined
- Nov 12, 2007
- Messages
- 6,431
- Reaction score
- 3,311
My friend made 1025 whp on his blow thru bbc with a a1000 so i know tour good to atleast that lol
Nice carb is it yours
No, mine just has regular bowls with single seats since it's on a N/A Hemi.
This is the pump that started it all. Durable, reliable,
good looking and it supports high horsepower. Perfect
for the daily driver that doesn't run like a daily driver.
Fuel Injected Engines:
up to 1300 HP - naturally aspirated
up to 1000 HP - forced air induction
Carbureted Engines:
up to 1500 HP - naturally aspirated
up to 1200 HP - forced air induction
ORB-10 inlet and outlet ports.
For EFI applications use regulator P/N 13101 or P/N 13109.
For carbureted applications use regulator P/N 13204.
Fully submersible for custom, in-tank placement.
Perfect for 'blow-through' carbureted engines up to 1200 HP
Brother you don't run forced ind. but on the other hand you do have a HEMI , got a pic
I've got draw through build on this site somewhere. I'll get some pics of the Hemi soon as I've got the block out at the machine shop. I'll probably post some pics of the engine , and the car as well.
Here's an old pic.
Can you sand that crease off the center of the hood?
I know it sux lol
Dude, you just got blown away, talking about your 1000hp ain't going to change that..and if it's not under load, is it actually producing 1000HP ?
You figure it out then Bro. 3400 lbs and 138-140 mph in the 1/8th.. Spinning..
