dibbons
How do a couple of allen bolts support the persons I have seen sitting/standing on the wings? Anyone have fotos of the wing off the stabilizers so I can see how large/long the allen bolts are?
Did you know the engineers said that a 9 inch wing work the same as the final production wing but the taller one was way more intimidating. I wish I could remember where I read that.
~ Test Question of the Day ~
For all you 1970 Plymouth Superbird 'experts'.
What was the dimension specifications of the Rear-Deck Wing.
* Height of Wing {From the Trunk-Deck to Top of the Air-Foil Wing}
* Air-Foil Wing > Width and Length
* {Vertical Supports} > Width and Height
* Weight of 'complete' Rear-Deck Wing assembly.
* Air-Foil Wing > Type of Material
* {Vertical Supports} > Type of Material
* How many bolts to fasten each {Vertical Support}.
* How many under-deck support braces in Trunk.
I will be checking, because I have 'all' the answers.
It seems everyone has fond memories of these cars..
Proper Names
* Vertical Fins.............. 'Stabilizers' {Stanchions}
Part #3571138 {Right}
Part #3571139 {Left]
* Braces {Front}........... 'Stabilzer Supports'
Part #3412764 {Right}
Part #3412765 {Left}
* Braces {Rear} ............ 'Stabilizer Supports'
Part #3412790 {Right}
Part #3412791 {Left}
* Reinforcement Plates ... 'Stabilizer Shoe-Plates'
Part #3571134 {Right}
Part #3571135 {Left}
* Air-Foil Wing .............. 'Horizontal Wing'
Part #3571137
* Wing-Insulator ........... 'Vibration Gasket'
Part #3571136
Krazy you've been schooled by the keyboard professor !!!!
Where is my answer to how a wing can support that weight with only one small bolt on each side?
You answered 'some' of the Test Questions, but not 'all'.
As 'The Professor', I must grade your test as an 'incomplete'.
I well send a note to your parents.
You still haven't given the dimensions for the wings that you asked.
You think "die cast" is a material, when in fact it is a PROCESS.
You did not answer half of your questions, which is below 50% and you get an "F"...
You are no professor, you aren't even close to a teacher, not even a teacher's assistant...
Ah, yes 'Grasshopper' that is a good question. You are wise.
First, the Air-Foil Wing {'Clark-Y Foil'} is made of high-strength aluminum.
Second, the Allen-Head wing attachment bolts {Part #3412637}
were 'black-phosphate coated' units.
They were very strong 'Grasshopper'.
Learn It, Love It, Eat It.
99.9% of the questions here can be answered by looking them up on aerowarriors.com
:thumbup::thumbup:
Phosphate coated bolts.
Too bad MOPAR didn't coat all the cars.
Maybe I wouldn't be doing so much rust repair.
Some cars are indisputably ugly. (Yugo?)
Some cars have love them or hate them looks and are debatable
(Guess which 1970 car I'm thinking of.)
I think ugly isn't the right word for a Super Bird.
The word is garish.
And that might not even be the best word.
Perhaps "jarring".
That's why Joe driver didn't want them.
(With exceptions)
"Honey, I bought a bullet. It's got a tail."
Yea, that would work.
It is simply a missile with a wing.
And besides that, it is the only car in the whole wide world that is cooler than a Road Runner.
Beep Beep. How do you top that?
I'm still waiting for my Aero Duster kit.
Incorrect most Honorable Son.
You will not find;
* Length of the Air-Foil Wing
* Width of the Air-Foil Wing
* Weight of the Air-Foil Wing
* Length of the Vertical Stabilzers {Stanchions}
* Weight of the Vertical Stabilzers {Stanchions}
* Angle of the Rake
* Thickness of Rear Deck Wing and Vertical Stabilizers
* Correct size of the Wing-Attachment Fasteners {Allen-Head Bolts}
Don't ask "El Loco Kuda' for this information, because he has 'nada'.
The above information can be found at;
Buca di Beppo
Orland Park, Illinois
Ask for '69 Cuda 440'
