Pull the trans with it. From the bottom.
rather just pull the motor
"With it" means engine and all.
pulling the 360,will the trans (727) mount support the tranny by itself or will i need other support?
^^^^^^^ Ratchet strap, rope, or chain across t/bars.. to hold it..
For install,, Put a piece of wood under the trans pan,, and jack/lift the trans till the bellhousing is lightly pinned to the floor and can't move,, then install motor..
removing jack after engine is secure to the trans, and before lowering it onto the mounts..
great,thank you.i may pull them both while im at it and have john cope go through and freshen it up.im pulling the 360 magnum and have mike at mrl build me a 408 stroker.i cant wait to get it done.ive heard mike is really good at stroker engines.its going to awsome to have a 500 hp small block.
Nice name drops; must be nice to be independently wealthy... :roll:
Yeah it's gonna be nice, nicer if you build it with your own two hands.. Since your into the bought not built thing, then he's right up your alley!
Ok. I was telling you the easiest way. Go for it.
What I did on mine was to simply put a cheap ratchet strap across the T bars, under the front of the bell. When I put the engine back in, I did have to jack the front of the TF up a little to get things aligned. Didn't even remove the hood.
