rrvolare 19Swinger69 Joined Jan 25, 2010 Messages 1,737 Reaction score 127 Location Michigan Nov 9, 2016 #1 Any photos showing where you ran your harness for gauges in bulk head.. where did you drill if any ?
Sedanman 67-9 Valiant specialist Joined Apr 3, 2009 Messages 8,536 Reaction score 593 Location chicago Il Nov 9, 2016 #2 You don't need to drill into the body if you use the firewall plug below the master
T tjpatte Well-Known Member Joined Jun 22, 2015 Messages 881 Reaction score 841 Location San Diego Nov 10, 2016 #3 Sedanman said: You don't need to drill into the body if you use the firewall plug below the master Click to expand... This is what I did. Used a rubber grommet in the hole I drilled to protect and seal the wires.
rrvolare 19Swinger69 Joined Jan 25, 2010 Messages 1,737 Reaction score 127 Location Michigan Nov 10, 2016 #4 i understand that .. but where exactly did you drill .. i have a 4 speed car
4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 39,966 Reaction score 23,428 Location Ontario Parts Unknown Nov 10, 2016 #5 Large red wire and large black wire. Red is on innermost plug on very bottom inside. Black is on middle plug 2nd down from top
