Nov 9, 2016 #1 rrvolare 19Swinger69 Joined Jan 25, 2010 Messages 1,737 Reaction score 127 Location Michigan Any photos showing where you ran your harness for gauges in bulk head.. where did you drill if any ?
Nov 9, 2016 #2 Sedanman 67-9 Valiant specialist Joined Apr 3, 2009 Messages 8,536 Reaction score 592 Location chicago Il You don't need to drill into the body if you use the firewall plug below the master
Nov 10, 2016 #3 T tjpatte Well-Known Member Joined Jun 22, 2015 Messages 875 Reaction score 836 Location San Diego Sedanman said: You don't need to drill into the body if you use the firewall plug below the master Click to expand... This is what I did. Used a rubber grommet in the hole I drilled to protect and seal the wires.
Nov 10, 2016 #4 rrvolare 19Swinger69 Joined Jan 25, 2010 Messages 1,737 Reaction score 127 Location Michigan i understand that .. but where exactly did you drill .. i have a 4 speed car
Nov 10, 2016 #5 4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 39,696 Reaction score 23,047 Location Ontario Parts Unknown Large red wire and large black wire. Red is on innermost plug on very bottom inside. Black is on middle plug 2nd down from top
