QuickDart360
What oil weight and type of oul do you guys use in your 340 and 360's? Multi weight single grade? Synthetic or conventional. I am especially interested in flat tappet cam oils choices!
Never run a single grade oil. Don't do it.
Buy the best oil you can afford. I gladly pay 24.00 a quart. My cam, lifters and rings love me for it.
Yes. And they will all be correct. But some of us know better than to the question literally.There's going to be as many answers as oil.
Let's do spark plugs next....
can you explain why not to use a single grade oil please .
Exactly. Short explanation is:single weight only if you pre heat your oil for a race
20/50 Lucas hot rod oil. Lots of zinc, lots of cling for cold and infrequent starts . My aggressive flat tappet likes the stuff
Grafico de viscosidades: Motores
I use Eurospec 0W-40 Mobil-1, Penzoil Platium, Castrol made in Europe, etc if it meets the Mercedes .29 spec the natural gas base oil has tremendous film strength
read his corvair oil paper if you have not- hyd flat tappett
Oil selection | Widman International SRL
straight 30 even in san antonio is going to have more wear
