That's pretty! No really!Well, still dont know how big a 5.2 can get but mine is 323 now. Getting back together during winter...View attachment 1715283719
A sonic check will tell the machinist how far he can bore out the block safely.Well, still dont know how big a 5.2 can get but mine is 323 now. Getting back together during winter...View attachment 1715283719
Thats what I thought and decided not to stroke. I want decent street manners and best possible gas mileage, RON 98 is 1,50€/ litre here, that means its 6,50$/ gallonI don't think it needs a stroker kit based on what you're doing. Sure it would be nice to have all that torque but you're also throwing gas mileage out the window, 5.2L up to 6.4L. Kind of nice to have in a grocery getter especially with European fuel prices, JMO
Thats what I thought and decided not to stroke. I want decent street manners and best possible gas mileage, RON 98 is 1,50€/ litre here, that means its 6,50$/ gallonI also decided to feed the engine with Pro-Flo4 fuel injection to support those things. Engine is slowly getting somewhere, next thing to do is to measure piston to head clearance, pistons are sticking .018" up from the hole so with Fel-Pro 8553 gaskets I should get Quench around .035".
Well that explains a lot!!!!And jug of milk - of which I buy 3 per week,minimum, of which I drink 2 by myself. I love milk!
Wish I could get a tanker!Wow, fuel prices here are literally one-third of that, fuel station near my house has 91-octane (RON+MON)/2 for I think $2.25/gallon? Even still I'm happy my engine will only be 9:1 compression I should be able to run 85-octane regular gas or at the very least 87-octane midgrade. Too bad I can't ship you a barrel of cheap American gas
With good quench and compression like you're building for, those heads which have good air velocity esp. with the smaller intake valve, and the Hughes roller cam, I bet that engine will run great at all speeds and have a nice fat torque curve for the relatively small displacement.
Our gas prices have been dropping this winter which is highly unusual. With an exchange rate of 1.33; the price equivalents of 87E10 are from as high as 6.49 per USg last fall, to currently 4.79 per USg.
Just to compare; a 2 liter bottle of Coke costs the equivalent of 8.96/USg.
And jug of milk is 9.68/USg equivalent, of which I buy 3 per week,minimum, of which I drink 2 by myself. I love milk!
No; a 2liter jug sells at the rate of 8.96 USgallon, so you can compare it directly to gas. The bottle itself is 3.70C per 2 liter bottle or 1.95C per liter.Smaller quantities out of refrigerated coolers cost way more comparatively, and I only buy by 2liter bottle.
As for milk I buy a 4L jug (3.64USg) at the convenience store for a tic over 8.00C, or about 5.50C to 6.50C at the big box grocery store. These also cost comparatively way more in smaller quantities, and are taxed. Many things we buy are taxed in smaller quantities/ exempt in bulk;the idea being that smaller quantities are a convenience for a well-to-do person, whereas someone buying a jug of it is buying it for his poor family, so deserves a break. Hey I didn't make this system up.
A typical wage for a trained common-tier tradesman or laborer, is about $18 to $20 per hour. So that breaks down to average about 4gallonsImp per hour of average gross wages. But I gotta tell ya, gasoline still seems reasonably priced,when figured this way. In 1969 gas was 37 cents a Canadian gallon and I was making 1.50 per hour minimum wage; this then being 4 gallonsImp per hour's wage. Gas is about the only commodity to have remained like this.
We are lucky to NET 70/75% after income-taxes.
Our combined Provincial and Federal sales taxes is another 13%.
Milk is sales tax exempt in 4L jugs.
Gasoline, Alcohol, and Tobacco are taxed to the extreme.
Well, this didnt go as planned... Somehow Ive got piston to head clearance everything between .038 and .047 .038 is good but .047 is not... Dont know wtf should I do, block is decked allready and crank balanced.Engine is slowly getting somewhere, next thing to do is to measure piston to head clearance, pistons are sticking .018" up from the hole so with Fel-Pro 8553 gaskets I should get Quench around .035".
Tell me about it... Ive been trying to figure this out all day, I could get 4 pistons shaved and then use thinner gasket, but how about my balancing then? .008 shaved off a piston, how many grams is it?ouch![]()
Hi. Your in Finland ?? 2 options: 1 isn't a 'Magnum' Block but Scrounge around for a wornout 240 or 250hp Chrysler Marine Sterndrive engine: its a thick bore/casting H/duty Block with ALL the goodies ( & I mean ALL the factory H/duty goodies: bushed/floating small end ",Truck/Industrial Rods High Pressure oilpump, 273ci Commando Single Plane 4bbl Intake , big 4bbl AFB, STEEL crank, etc etc) OR if some Intl freight isn't out if your Budget there's an Engineering Business in Australia that makes Custom overbore size pistons with pins & rings supplied.I was looking for a 5.9 but those are rare here in finland, pickn pulls were asking 1500€, its almost 1800$
I was thinking about stroking, but that includes 0.030 overbore also and a 2000$ plus freight plus taxes so ill be in 3000$ then...
Semi-delete that last reply of mine: I replied to a muchvEarlier post of yours...but, how high are you going to spin that. 318 ?? - that's a high Rev midrange torque manifold like hovering around 4'500 rpm constant like circle track. + things can't be TOO expensive in Finland if you've got KB pistons & proflow injection. ,( not as tough as here in NZ, we pay near 45% extra to $US with exch rate + the high cost of Shipping 9,000+ miles, then there's the +15% GST which then incures another $176+ flagfall in customs' creative surcharges.Not much progress here, pulled three pistons and noticed there were strange scratches in 1st rod bearings. Now I have to find out what caused it, rod is in machineshop and theyll measure it. If its round, then its must have been dirt what caused it, but I have to find out.
But hey, I got my Proflo4View attachment 1715300500
JP Engineering try google jpengineering.com or jpengineering.co.au I know the owner Laurie - Tell him Trev from NZ sent you. He'll make you Std +080" block savers or any feasable overbore req.
I read in a Hotrod mag Magmun blocks didn't like much over +030"_ +040 without sonic testing & your pushing it: Suggest a Welded up offset ground Stroker Crank done locally with a Custom Compression height piston to match: +.060" 318 takes you to 327cubes, did 1 with smooth flattops: not valve reliefs & pocket ported heads & that was a Stormer , IF you find an ex Chrysler Marine they've also got a high torque H/duty Starter Motor, which is a cheap way to get something to swing the project over + save those Intl EBay type Shipping costs :-/
Goodluck .Trev
Well, im thinking the engine should easily rev to 6000 and with my gears, Im in 2700-2900 range at highway. The intake is a bit overkill, I know. But thats what edelbrock has decided to offer to this set. There isnt much options for mopar EFI intakes, in fact super victor is the only oneSemi-delete that last reply of mine: I replied to a muchvEarlier post of yours...but, how high are you going to spin that. 318 ?? - that's a high Rev midrange torque manifold like hovering around 4'500 rpm constant like circle track. + things can't be TOO expensive in Finland if you've got KB pistons & proflow injection. ,( not as tough as here in NZ, we pay near 45% extra to $US with exch rate + the high cost of Shipping 9,000+ miles, then there's the +15% GST which then incures another $176+ flagfall in customs' creative surcharges.
Cheers anyway. T
