Richard Guarneri
Member
Going to look at this car i know it is one of 40 trying to get a value to make an offer if anybody out there can give me a little advise or where to look i would appreciate it.
Thanks
Thanks
yes the only thing missing is the carb and intake manafold ?Is that the original big block?
yes this is why i posted here looking for existing owners feed back was that plate painted from the factory. i would like to know were the fender # are and the block # is so i can check for a matchWhat’s the story on the fender tag? Why is it so rusty when the rest of the car isn’t? Seems odd.
thanks for the input do you know where the block and fender # are locatedIf a legit numbers car and restoring back to OEM there are many factors of course. If the body has little to no rot I think $10-15k would get you there considering what it would take to reach an OEM rotisserie build which could be worth $50-70k. It’ll take at least $30-40k to restore it proper. At the end of the day you’ll be into it for $40–50k. If looking to build and sell you are looking at $10-20k profit after about 2-4 years of personal sweat and tears.
If adding to your collection As a dream car then it’s priceless.
That doesn't work on '68 cars...VIN stamping started in '69.
but the number in the trunk should match the build number on the tag. no vin on the tag or bodyThat doesn't work on '68 cars...VIN stamping started in '69.
right, but as long as the drip rail build# and the body tag build# match, you know tag matches the body. unless that part was welded into the car without any sign of itYes, but it doesn't tie to the VIN...need the build sheet for that. Fender tag can be replaced...VIN tag harder as it's special rivetted.
there is build # on the trunk drip rail of ;68sThat doesn't work on '68 cars...VIN stamping started in '69.
The way it sits he thinks he can get $ 30,000 as is after my research i am in at $10,000 to $ 15,000Sweet car.
Lets try this......What is he asking ?
