The bearings are as some of you say, flaking apart, there are pieces missing from a lot of the edges and chunks out of the middle on almost all of them. I'm going to pull the motor, as hellrats said to check the rod bearings, and I agree, I want to check them all for piece of mind. The motor was losing power and some oil pressure and I wanted a bigger cam any way to go with the better heads, when I pulled the cam some of the lobes were going away, I don't know how I missed the bearings! I gotta say you guys are freakin' awesome, many thanks to all of you, with the help I'm sure I can get this done with no problem. I've never changed cam bearings but I'm pretty good around a motor so this will be a piece of cake. Thanks again to all you fine FABO friends. And if any one is interested, I mentioned my bad back and I know some of you here suffer with it, I'm not talking a back ache, I'm talking serious problems. I was in a car wreck in the late eighties, a guy ran a red light and slammed me in the drivers door. Well as the years went by I've had every treatment in the book and just this least year everything stopped working, so my Doc talked about an Abbott spinal cord stimulator with BurstDr. A unit about a little bigger than a zippo lighter is inserted in my back and a wire runs up my spine, what the thing does is trick the brain into thinking you don't have pain and I have had mine for about a month, my life has totally changed, I went from crying from the pain to just about running around the yard. So look it up or talk to your Doctors because this damn thing works. I think it was crackedback who started a thread talking about his back troubles. Thanks for the help and Thanks for listening.
Jeff
