What headers have members used with Speedmaster aluminum heads? How is the fit with the spark plugs etc. ? My application is 69 barracuda, small block 360 , power steering ( Borgeson box) and power brakes. Thank you.
I have Speedmaster heads, Stock PS box (from Feel Stage 3), Doug's headers, Z-Bar, 90's Mini Starter, CVF Brackets for Saginaw box, poly motor mounts on a 69 K Frame and it all fits with minimal issues. The header bolt holes were tight but I didn't need to open them up to fit. Plug access is like Doug's with stock heads, pretty good.
Those would be the ones.Is it d453?
The only issue I had was with the factory power steering coupler hitting the back tube. I replaced the steering column with a Flaming River for a B-Body as I was was converting manual to power at that time.
Thanks for the info. So maybe a smaller than factory coupler would do the trick.
issues
Wait a minute I'm going to have trouble with my alternator!? Do you have a picture of the fix? So I can get prepared...I replaced J heads with mine. Had the pop up 340 pistons fly cut to Zero Deck. Other than head bolts/studs that fit Edelbrock heads all stock stuff bolts up. They have the same Alternator fitment issues Edelbrock heads have.
He ain't drove it yet...As far as performance , how did the motor respond to the head swap?
I get that about being busy and all but now as a result the suspense is killing me too.Totally. I'm so close too. If I had about 2 full days on the car it would move under it's own power again. I'm constantly under a hail storm barrage of family needs and work.
Had 16 days off over Christmas/New Year and not one second spent on the car.
Still waiting for information about alternator fitment here too.Wait a minute I'm going to have trouble with my alternator!? Do you have a picture of the fix? So I can get prepared...
