Righty, glad to see you got the oil dripper for the cam chain on, don't forget the oil slinger washer on the crank . . and eccentric for the fuel pump on the cam as you know . . .
Hmmmmmm..... I may see an issue on the cam timing. Look back at the 1st pix in post 118. It shows the cam dot at 6 o'clock. Both #1 and #6 cylinders should be at TDC in this situation; #6 cylinder is visible but its piston is nowhere close to being at TDC. Also, the crank key is not visible where it should be in this pix (around 1:30 o'clock when viewed from the front).
Back up OP, and set #1/#6 at TDC. Once that is done, then look to see if the dot on the cam is at either 6 or 12 o'clock. I suspect it will not be, based on this pix. However, you may have corrected this in-between times, but please re-check since the pushrod length check seems baffling.
The only thing I changed was to remove the timing set and rotate the cam gear so that when installed, both gears lined up at 12. I'm going to look and see where the pistons are when the gears are both at 12 o'clock.
Thanks George, I did get the oil slinger and eccentric installed, I just didn't post pics. Another thing I did was drill an oiler hole in one of the cam thrust plate bolts, as I saw in another build thread here.
BTW, now I get the joke from post 118...![]()
so what was it?
Question: Were the intake gaskets metal or composition? Don't want a coolant leak inside and outside the engine. Most everyone here recommends using the composition intake manifold gaskets with an AL intake.
And did the cork end gaskets under the intake get clamped down well?
Snout bolt on crank damper torqued to 135 ft lbs?
Why do I think there is something missing from the front of the passenger side head in the 1st pix above? Like a freeze plug?? What is that circular 'thing' in that freeze plug hole?
I don’t understand how it won’t work. The shaft of the old distributor mates directly to the distributor gear and turns the cam. Am I missing something?the old distributer wont work to prime with unless you did something to the shaft going down to the oil pump, it is interlocked with the cam gears. I bought my priming shaft from amazon quick and cheap.
Yes, but why can’t I use the old distributor?
Thanks for catching that! That’s exactly why I come here, I can’t tell you how many times forum users have saved my hide when I was about to go do something stupid.because it will spin the cam, deletes the purpose of priming the oil if you are going to be spinning the internals anyway, might as well just crank it over with the starter
