Thanks Kim. I’m going to remove the trans so I can get to the pump and drum. Roy is assuming the clutch teeth are a goner.
Getting close to the end. Gonna prime it one more time before installing the fan and radiator, then charge the battery and add fluids.View attachment 1715571114 Is it weird that I’m getting nervous the closer I get to being ready to start it?
Thanks George, very helpful info. Funny, I was actually going to ask if there was a way to prime the fuel system? I understand that I will prime the carb, but what about the fuel pump and all the lines? As everything sits currently, it is dry.
Well, I thought today was the day.
Pops and another friend came over to help out and act as extra hands and eyes. Good thing they did, because they spotted things that needed correction that I wouldn't have seen on my own. I wanted to flush the radiator prior to filling it with coolant, so my buddy plugged the lower hole while it filled so we could build some pressure to let the water flush any gunk out. The radiator filled and started to piss out water in a steady stream about halfway up on the fins. So that's that. I either need a new radiator or I need to repair this one.
Moving on, they noted that I had no fan shroud. Yes, that's because the fan I bought on eBay was a little larger than the OEM fan, and the shroud didn't fit. Well, this is when I learned that the shroud wasn't just for safety. So now I'm in the market for an OEM fan, which seems to be pretty damn hard to find. If anyone has a part number for a fan for a 318, I'd love to have it.
Slowly but surely, I'll get this car back on the road!
A leak 1/2 way up is usually an easy spot to fix, especially if it got nicked and not caused by corrosion. I have had good luck by carefully peeling back just a few fins and pinching the hole flat, then clean and flux the area, then using one of those mini torches and some solder (gotta be dry inside) has saved my wallet more than once.I was going to stop in at the local radiator shop to see how much he'd charge to repair my leaky radiator. It would be great to get a nice new aluminum job or even a new OEM unit, but my wallet is feeling a little light these days.
SHE LIVES!!
It took about 1 year to the day and a lot of learning, but the Scamp is running again. Boy does it sound wonderful. When we first got it started, I found some oil leaks and a coolant leak that needed to be addressed, so we shut her off and let it cool so I could get to them without burning the **** out of myself on the headers.
Leaks repaired, I adjusted the idle setting and got the timing correct (I think). It idles wonderfully around 900 RPM and is maintaining a steady temperature.
Took it around the block to feel it shift, but the alignment is pretty far out. I think when I adjusted the torsion bars to raise the front, I tweaked the camber. No worries, I have an appointment for an alignment next week. It’s on the trailer currently, ready to be dropped off at the shop.
Thanks everyone for all the help and support! This has been an incredibly rewarding journey.
