Good evening folks. I am baffled and am hoping someone can point the solution I’m missing out.
I have an older Edelbrock PVC breather port that is supposed to connect via a hose to the air cleaner #1205 fitting that mounts to my Edelbrock air cleaner. However if you look casually (or closely) you will probably come to the same conclusion I’ve come to.....the diameters of the hose fittings are radically different. The air cleaner attachment is 1/2 and the external diameter is about 7/8. The Edelbrock directions are fairly useless so I’m hoping someone can point out the obvious solution that I’m missing. I’d like to hook up the PCV if I can!
Thanks in advance for your help!
