Sirsmiley9
Has anyone used a quicktime bellhousing in an a body, because it does not actually mention if it will fit with an a body like the ones on brewers do
It’s a 75-76 so I need the larger retainer for the bellhousingYou can use the 4.807 front bearing retainer on the O/D. It has the same bolt pattern as the 5.125 O/D front bearing retainer.
On the OD transmission, the bearing itself comes I. Two different sizes?It’s a 75-76 so I need the larger retainer for the bellhousing
307 vs 308 bearing retainer
That’s what my thread was asking.Ok so i might be a bit slow understanding this but for that one did you take a bellhousing with the smaller bearing and machine a spacer? Sorry I’ve been trying to find a bellhousing specific to the 75-76 5.125 retainer but if there’s some way of taking an older bellhousing with 4.80 retainer ring that would make all this much easier
Ok so you have 4.08 bearing retainer with a machined spacer type thing that fills the extra space? would that work for other bellhousings and which ones. I’m kinda new to this and have spent awhile figuring out what bellhousing would work which I thought was only the one with the 5.125 inch retainer bearing but would something like this Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists work with an adapter ring to fill in the space between the retainer ringsThat’s what my thread was asking.
“Can I used a large bolt pattern 4.08 bearing retainer to replace the large bolt pattern wider 5.125 diameter bearing retainer on a OD trans.
I never said or implied that. Why are you putting words in my mouth?Ok so you have 4.08 bearing retainer with a machined spacer type thing that fills the extra space?
i think i just misread something or atleast picturing something wrong, sorryI never said or implied that. Why are you putting words in my mouth?
