Help! Can't Remove This Part!
MonkeyMadness
Yorba Linda California
Help I can't seem to figure out how to remove this upper window gasket/ trim work?
Grab, pull, work out with screwdrivers and putty knives (it is glued in).
Alan
think you're going to need to just tear it out or cut it with a razor blade. not trying to save it are you?
It’s not glued in, except maybe a little dab at the end where it flattens out. There may be a screw imbedded in the flatted area, inside the channel. Otherwise, it has flanged edges that “pop” into the metal channel and hold it in place.
See if the bows have paint marks on them and post the order from front to rear. Iirc someone asked about how they went in a while ago.
header bows front to back on my 69 cuda
orange
green
blue
red/pink
purple
Careful as it May have been changed from original. Hopefully the last person put them back in order as The original. It has added roof deadner not used by the factory so who knows if has been altered.
My 69 FB was from front to rear was
Brown
green
blue
pink
magenta/purple
It appears this is early A so?
