Hays torque converters?
rumblefish360
I have escaped the EVIL Empire State!
Florida
I was at Mancini racing poking around and stumbled onto this;
Full Race Torque Converter Chrysler TF-904
I never heard of Hays making torque converters. Clutch parts yes! Converters, no. Has anyone ever heard of or used one themselves?
And your opinion! (Of course!)
dont think you are gonna find any fast small block N/A motors running a 10 inch convertor, least i have never heard of anybody
I thought “depends on the application” covers that? You wouldn’t see that in an N/A small block for sure, but it depends on the application whether or not a 10 inch housing is enough.
Sorry about that. Sometimes i need to read better, bud.
Where would you most likely find a 10 inch converter?
What kind of application?
Converter diameter has very little to do with stall speed anymore. I guarantee you can call Hayes and tell them you need that 10" converter to flash to 5K and they can do it.
I get that. I just don’t know what the deal is with diameters vs what there used for and in. I do know that faster cars will have smaller converters. Less fluid inside to move? Would be the reason I guess.
Hays probably has them made for them. But won’t divulge who it is. The only real place where size matters is when u have a real heavy car such as a b body close to 4000 lbs and want to run an 8 inch which may not have enough fluid capacity for the application. Kim
Most of it has to do with efficiency. The housing and stator change stall speed and efficiency, plus the fin angle and some other stuff.
I’m WAY out of my comfort zone with converters. The little I do know I just posted.
For the chevy truck I just did the tunnel ram deal on the discussion between myself and PTC went back and forth on two things. One was what housing and stator diameter to use, and was my buddy going to run a big enough oil cooler to deal with what we needed.
To that end, the question was do we use a 9 inch housing and a 9 inch stator, a 9 inch housing and an 8 inch stator, or an 8 inch housing and an 8 inch stator.
In the end, it was the 8 and 8 combo. He has an oil cooler that was more than capable.
I know Tim at PTC was concerned that the stall was where it should be, and that the converter wouldn’t slip while driving it on the street, which makes a ton of heat. So that was why the 8 or 9 inch stator was in question.
As for using a bigger housing, if you’ve ever seen a power adder car “drive through” the converter because the power is high enough the little housing can’t deal with it, then you know that the housing and stator are too small.
Torque makes stall. So the 8/8 in my buddy’s truck which is 5100 flash stall with his N/A small block would probably gain (just going to guess here so don’t hold me to hard numbers) 500-600 RPM stall behind say a tunnel ram 572 engine with the exact same converter.
If that is too high, then you have to increase the case size and stator to get the stall speed back where you need it.
Now take that same 572 and add the hose to it or a pair of hair dryers and the added torque just makes the stall speed go up.
Vehicle weight matters too. The lighter the car, the smaller the case to get the same stall speed, IIRC.
That fully taps out what little understanding of torque converters I have. One thing I’m positive on is that torque converters have come a BILLION miles from where they were when I started driving/racing in 1980. A BILLION miles. Today what companies like PTC, A-1...now I can’t think of some of the better companies...the dude that started the bolt together stuff...what they do is phenomenal. It’s nothing like it used to be.
In 1985 if someone told me they were using an 8 inch converter on a 75% STREET driven car, they’d have locked you up in a padded room. That was unthinkable. Today it is very mundane.
Thanks. Most of that I understand and sort of knew. I’ve come to learn a good bit here at FABO with those that know and a few questions. Like yourself, a manual trans is what I Whoo-Ha around with. If I’m not rowing my own boat....!
I however yet don’t understand where a dividing line is and why you couldn’t or can’t use a 10 even though I would be told an 9 or 8 is what the car needs for best results.
Perhaps in the old days, you would use a 10 inch restalled higher to meet the need for a regular street hot rod? It made me wonder... so hence the post... why would they offer a 10 inch only. A generic size for a generic in general street bound hot rod that see 10% track?
When it came to my wife’s car, I did the same thing when you don’t know enough to write out the front page of a pamphlet..... I called a professional. “Pro Torque” used to be a short 3 mile drive from me. There in Pa. now. I spoke with the owner and he re stalled the stock old OE odd spline 904 converter & added some good parts. He told me your good to go to 600hp+. Finding a converter for the older 904’s proved fruitless.
Rumble, did you end up buying a Hays converter?
Thinking about one myself.
Wally
No. I got tired of delays & excuses for 5 months. I went with the fellas down the block from me (but since moved) and had a custom one built. A good bit more $$$ but with more power handling capabilities. 650HP.
Pro Torque is the company. https://protorque.com/
This page; https://protorque.com/product-category/converters/pro-drive/
There part of the Boninfante friction Corp group.
I got a 9.5 Pro Drive Series 3500+
I’ll be getting to this next year.... maybe....
Thank you!
I’ll look into them.
Maybe, maybe not. The way converter technology is now, a faster car may or may not use a smaller converter. It all depends on what the best match is for the given combo. At least in THIS day and time. Used to be what you said was true across the board. Smaller diameter converters were used in faster and faster cars. Now, not so much.
Was looking at them and they list a 10 5000 stall converter for $700.. lol
