TrailBeast
AKA Mopars4us on Youtube
I normally use 3M clear double stick tape for emblems and other small detail parts that mount surface to surface.
The other day I found this stuff in the general office supply section at Walmart.
Works as well or maybe better than the 3M stuff that I normally have to order WAY more than I need.
You apply it then trim to match the part being applied, then peel off the backing to leave only the clear glue.
Super tacky so you need to be sure of placement before it touches.
