I found a Great deal on CL for a brand new Comp XE268 cam kit (cam,lifters,springs,keepers,seals,retainers,timing set).
I have checked the forum and know that this is a popular cam in a SBM. I know this won't be optimal in my LA360 but sounds like a good performer for my current combo. WITHOUT GETTING INTO A CAM SELECTION WORLD WAR....do you think I will be happy in my B-body? I use it for spirited cruising and twisty roads with 30% highway. Need somewhat decent fuel mileage (>15?). Need good torque (advance 268?). <6000RPM.
Yes I will need pushrods and yes I am concerned about the lifter quality.
Current mill has about 8000 miles on it. Runs great but down on power.
1978 LA 360 .030 Stock replacement dish pistons.
1978 LA 360 smog heads. .042 milled. Pocket ported.
150 psi cyl pressure (Crane H260-2 current 204/216,260/272,427/454)
Stock springs. Stamped steel rockers shimmed. Not sure the amount. Slightly longer pushrods. Not sure the amount.
Mr Gasket thin head gasket .028
Estimated CR 8.4.
Edelbrock Performer intake (milled to match heads) with 1406 600cfm carb.
Windage tray and intake shielding.
340 HiPo manifolds and 2.5" exhaust. Have long tube headers to install.
904 auto trans. 340 2400? hi-stall converter from Pat Blais.
3.55:1 SG. 26 inch tire
Car weighs about 3600# 72 Satellite.
26 inch tires.
Power brakes, power steering and A/C.
Options
I have a set of EQ 1.88 heads, Air gap knock off and Holley street avenger 660 but I
am saving for my never ending 360 Magnum build and my intention is to sell the running LA complete when the Magnum is finished.
Estimated CR 8.4.
26 inch tires.
Options
