600 grit? I have used 800, but I had always thought 600 would be too gritty. I guess not, eh?Got the first 3 coats of clear on today. Let it dry for a few days then sand it with 600 grit. Then ill spray 3 more coats. After that wet sand & buff.
thank you for your service my friendAs an old Jarhead, I stand and salute. Outstanding, sir.
PPG deltron clear mixed 4:1 with a hardner dry times depends on booth temp i try to keep my booth at 75-80 when & after i spray ill let it set for 2 -3 days before sandingIs this a catalyzed clear? 600 seems way too aggressive. What does the paint supplier recommend for dry time before recoating?
i dont mind buffing its the wet sanding i dont likeI've cleared over a lot of 600 before they told me the number is 800 for that. Looked fine to me. Cutting and buffing sucks.
Great job cawley
yep retro is the look he was going for
