Moparbrad
You don’t know me
This is a real 340 4 speed swinger. The car is a southwest native so rust isn’t an issue. Just needs the lower quarters replaced. I have nice lower quarters cut off a parts car included. Upper radiator support is cut but I have an NOS one included.
Bench seat, 4 speed, manual everything, green on green car.
Missing the original engine and trans. Included is a standard bore, non vin stamped 1970 340 engine that is disassembled. Has big valve J heads, rods and pistons, windage tray, oil pan, 70 dated timing cover, 340 Carter AVS carb, correct valve covers and air cleaner and LD340 intake. Have a 4 speed trans, I believe it’s a 69. Have the bell housing, shifter and linkage! Have the correct length drive shaft too. Original radiator and fan shroud. Complete rallye wheels with center caps and trim rings. Still has the 8 3/4 rear end, front disc brakes (calipers are in the trunk), rallye dash is cut for radio, have the factory radio, 4 speed hump is cut up but repairable. The car has the dash vin, fender tag and clean title.
I’ve been busy lately but I will work on getting more pics, probably next weekend.
$7500 located in Phoenix, AZ.
