cherokeechief79
is this also 5 on 4 or 4.5?
As a rule of thumb, all A-Bodies from 1960 up to and including 1972 were small bolt pattern front and rear.
(4'' bolt circle with 7/16'' wheel studs X5)
And starting for the 73 model year, all V8 and slant 6 with power brakes got the big bolt pattern front and rear.
(4 1/2'' bolt circle with 1/2'' wheel studs X5)
And, all A-Bodies built after December 31, 1976 were all big bolt pattern regardless of engine.
Your '67 Coronet wagon is a B-Body, and all B-Bodies had big bolt pattern. (5 on 4 1/2'')
That is of course unless someone changed it to small bolt pattern, which is highly unlikely.
So, you could get an early 1976 Duster slant six with a small bolt circle? Wow!!
Thanks for the correction.December 31, ‘75.
On Jan 1 ‘76 the federal mandate for front disks kicked in, and they were all 5x4.5”.
Also, power brakes wasn’t the determining factor. All V8 A-bodies starting in model year ‘73 had disks regardless of whether they were power brakes or not, and starting in '73 all the disks were BBP. /6 cars with no options were standard drums, so, SBP. But if they got an option that triggered disk brakes, they were then BBP.
My '74 Duster was a /6 with factory manual disks, BBP. It was one of the only options it had, but it came with them as a factory option.
Yes. But it had to be /6 car with standard drum brakes. If you got your /6 with a sure grip, or 3.55 gears, that triggered front disk brakes. Same for the optional towing package, you could get a /6 with a towing package, but it would have disk brakes!
These are from the '73 Dealership Data book, courtesy Hamtramck Historical The 1970 Hamtramck Registry - 1973 Dodge Dealership Data Book - Dart
