rear spring u-bolts
dartkid69
Active Member
windsor
Evening.....Is there a torque value for the u-bolt/nuts used on a 1969 Dart 340 auto? Also the nuts are they grade 5 or 8 or ? Any help would be appreciated, thanks.....Ric
Mancini racing has many
The u bolts have a flat on the U end of the bolt, and the nuts are self locking.
The torque spec will be in the Factory Service Manual. IIRC it is like 45 lbs.
Too much and/or the wrong U bolts WILL crush the axle tube.
I am assuming 8 3/4"
Dana 60 and 7 1/4 are different tech
Morning....Thank you for the response, yes it is an 8 3/4, I did get a new set of bolts already, wanted to make sure I use the correct torque and did not realize too much would crush the axle tube....Thanks
I have a housing I bought from only seeing photos and the tube is crushed at two u bolt locations. It even says so in the FSM.
GO TO mymopar.com and download a PDF service manual. It's free
45 lbs :eek: no way!!... 1/2 in fine thread u bolts I would start with 75 lbs,drive the car re torq to 85lbs.Then recheck after a week and and torq to 90 lbs...
Some of those 4x4 1/2" U bolts require 125 - 150lbs
You WILL crush the housing tube.
That's not warn it is crushed. You can see the crush on the inside of the tube.
Remember that 8 3/4 are formed flat stock metal to make the tube NOT extruded pipe
I guess I'm thinking 3" 150 wall round tube Dana...For me if it was my 340 A body I would start at 50lb and check it weekly for the first month with the new hardware installed...
