Frank Mopar
My buddy has one of these. What is it? Sorry only one pic.
Doesn't mean it won't work, or that it works well. Just means have a spair with you in case it dies. Same holds true for OEM Mopar electronic ignition and dist.POS. Thanks guys!
That would chase me away right there.I don't know where to get caps/ rotors for them, but the module is out of a Holden I believe. that module is evidently fairly popular overseas.
I've had the big cap GM style Skip White distributor in the 351M in my F250 for 8 years and it's never flinched.I had a new one in a small block. Yea its Chinese junk, but it did work fine for the 2 years I had the car. Never had an issue.
67 Dart is correct.
That is a Chrys Australia 318 dist. The same design was used in a number of Aussie cars, 6 & 8 cyl, for many years & are extremeeeeeeeeely reliable. It is a Bosch dist & uses a 4 pin module [ under the alum cap ]. It can be interchanged electrically with a GM 4 pin module if you reverse the pick up connections. Module mounting centres are the same, but terminal layout is different.
Correct.If that dizzy has a module attached to it does that mean its used without and external module and ballast?
