mygasser
quote :- ''better crank (good for 5-7 psi?)'', what do you mean by that? the crank won't alter compression at all if that was what you meant?
YesSo the answer would be.............323 cubes..........
Yespossible very low compression,
Good for 5-7 psi? On what? Changing the crank material is for strength. This adds no LSI anywhere on anything!better crank (good for 5-7 psi?),
I call BS on anyone saying a 318 can go to a 330 bore size.could possible bored to have a 340 piston,
Depends on the target of the build. You can have a fine running engine @ 7.5-1 ratio.if not would require decking and/or some upgraded pistions to run well.
Let’s do some math here. 3.94 bore size, 2.05 + 1.60 = 3.65 which leaves .029 to have clearance for the valves to operate.Better flowing head than a 318 stock piece with 2.02/1.65 valves.
What is your concern specifically?Is this recommended other than the comp concerns?
Roger that Sir!Not asking for hp estimates, usage projections, convertor sizing, DCR, etc, etc, etc.
The engine below looks good. Headers looks like standard 1-5/8. I still can’t tell what intake that is though.It is what it is. It in the car. Here is a photo. Basic SBM. Some may be able to id the head, not me. That will happen Wed's and I'll have a comp gage in hand.
Or oil psiquote :- ''better crank (good for 5-7 psi?)'', what do you mean by that? the crank won't alter compression at all if that was what you meant?
You wrote down a number, 2.05. I just did the math.Fish,
I'm comparing a stock 1.8x 318 valve to a 2.02 340 valve diameter. Cmon Man!
I’d laugh at this… because it’s funny as hell, but since your now making a political twist to things and opening up a can of worms, look in the mirror on BS talking and dumb *** goal post moving while twisting the facts and interjecting horse **** on what there think/talking about without actually saying it but leaving it to be assumed by the person replying which he will not and even more so because of the fruitless and wimpy roast attempt he made up front in the thread he started on not knowing a ******* thing but had holes of a working crystal ball.Do you work for MSNBC?
A lot evidently!!!Quasi Concern. I'm pulling the trigger on this and want some input on the combo in case I was missing something.
Where is the compare? This is what you wrote!Fish,
This place is like the old dudes on The Muppets!
One of my favourite colours on a Mopar.
