[WANTED] 360 SB Flywheel
Mean416
Georgia
I'm looking for a flywheel so I can run my engine on a test stand without the torque converter. Since this will be low rpm and not used with a clutch, an old worn out flywheel could be fine, all it really needs is that the starter ring gear is in decent shape.
None. I have a starter adapter plate which mounts the starter without the need for a bell housing
if 74 360 Dart Sport doesn't come up with one, I have a truck 360 flywheel. It's a bigger diameter, so, your starter adaptor would need to be adjusted out to match. Shipping would probably cost a small fortune however....
Here is the neutral balance 318 flywheel adapter plate to run on the external balance 360s.
Have one on the 360 on the engine run stand right now with a '69 318 flywheel.
Works fine, starter reaches the ring gear.
Put in 1/8" longer crank bolts if you can find them. I am using the stock crank bolts for the engine tests.
Hmmmm . . . .
Here is something I never thought about with this 360 balance adapter plate.
Let's say you have a neutral balance automatic to run with a 360. It says you can use this 360 adapter plate with a neutral balance flex plate too.
Hmmmmm . . . . .
