jpstewart19
Installed an Intellitronix setup in my '73 Dart and all of the gauges work well except the fuel gauge seems to be reading in reverse (it counts up as I use gas). The fuel gauge worked well with the old cluster (only gauge that did).
Before I try replacing the sender anyone have any ideas? I made sure the sender was grounded well, and even ran a fresh wire from the sender to the cluster.
Open to suggestions.
