[SOLD] LA SB Holley Street Dominator intake manifokd
Demonx2
Florida - near Ocala
I've got a Small Block Holley Street Dominator intake manifold that I won't be using so it has to go. I'm guessing I got it somewhere along the way in a stash of used parts many years ago and it's been buried in the basement since then and shows a lot of "shelf" wear to prove it. It appears to be uncut/unported and I don't see any bolt hole problems. It has the outer set of carb studs still in it and someone appears to have plugged a couple of the inner carb holes. Note that I have never used this intake so could not vouch for how well it might work. It could use a good cleaning for sure!
I'm located in the Detroit area and looking to get $100 for it plus the ride to you.
Thx!!
OOPS...That is VERY clearly a big block intake. MY STUPID MISTAKE and I thank each of you for pointing this out. I sure would never want to sell an errant or misrepresented part to anyone so again, I appreciate the correction. I've clearly had my head in the Small Block clouds for a long time and it shows!! It's pretty darn easy to see this part does not have the Small Block coolant crossover in it! Duh!!!!
I have several other Small Block intakes and figured no need for this one. But I checked my big block hoard and only have a couple others so I need to keep this one for possible future use. I apologize for my error and will mark this as "Sold" just to clear it off the board.
Again, thx for pointing out my blunder and my apologies.
