I've got a Small Block Holley Street Dominator intake manifold that I won't be using so it has to go. I'm guessing I got it somewhere along the way in a stash of used parts many years ago and it's been buried in the basement since then and shows a lot of "shelf" wear to prove it. It appears to be uncut/unported and I don't see any bolt hole problems. It has the outer set of carb studs still in it and someone appears to have plugged a couple of the inner carb holes. Note that I have never used this intake so could not vouch for how well it might work. It could use a good cleaning for sure!
I'm located in the Detroit area and looking to get $100 for it plus the ride to you.
Thx!!
Thx!!
