Kendog 170
Let the boy go !
I just got a kit so I can fix my leaking TRW 1.06 pump. I would also like to firm up the steering a little. Do I need to remove or add a shim at the control valve. My own common sense tells me to remove as to lessen the spring tension / pressure. I just wanted to confirm. It does not say in the FSM pump section anly that it controls the pressure.
Thanks
Thanks
