Acceleration hits a dead wall
Also, do not overlook the inlet side of the pump. IE, rubber hose connection to tank, pick up tube, and most importantly the sock on the pick up tube.
On a slant six the eccentric is ground onto the cam as a lobe. If it is worn out the cam needs to be replaced. That said, I would not discount the possibility of a bad replacement fuel pump (even several).A few years ago I ran into this problem on a 318. Multiple bad pumps from several different sources. I did a "band aid" repair, to keep the car usable. About 2 years later I got another pump, and that one was fine. Just had to wait untill all the defective pumps got out of the system.
Back to the original program.
Check the fuel pump pressure, and also the volume. Put the hose from the fuel pump into a container, and crank the engine. The pump should flow at least 1 pint in 30 sec at idle. To check pressure install a "T" fitting between the pump and carb, and connect to a pressure gauge. At idle should have between 3 1/2 and 5 lbs.
Yeah good point. I noticed the other day that the fuel gauge stopped getting a signal for where the fuel level is. I was planning on putting in a new clean tank and fuel send unit as a mental checkpoint to ensure the whole fuel delivery system is completely new and uncontaminated.
Yep - just installed one so that I could get a solid metric on what the fuel pressure was at. Looks to be at 3.5lbs at idle after just starting it up.
Good call on the cam lobe wear. I have no idea how many miles are on this 225.
So my question is ... is 3.5lbs of pressure enough? I notice when I punch the throttle the pressure doesn't change (not sure if it should though)
If I was to install an electric inline pump like this one before my gauge, maybe that would be a quick low-budget test for the fuel pressure issue?
3.5 psi of fuel pressure is just enough to make it idle. Probably Not sufficient to drive normally. My opinion is that is low. And volume would be a bigger concern. If you could drive it and watch or video the gauge I bet it drops as you try to accelerate
Curious what would be your suggestion if the pressure is low, considering the manual Carter fuel pump about 3 weeks old. Would you recommend an in-line electric fuel pump as an alternative route?
Have you measured fuel pressure yet?
3.5 at idle should be fine but id think it should go up with rpm to least 5 lbs by say 3000 rpms... but im no expert!
theres a spec for the carb if its a carter probably no more than 7 psi max but thats a guess look it up.
Alright, installed a new fuel pump. Now I’m getting 5psi at idle.
Test drive - same result, doesn’t move faster when jammin the gas down.
I don’t know a way to capture the psi at the gauge while driving but it sure is an odd issue
Same fuel tank, lines, pick up, and sock?
What does the timing advance to when you rev it in neutral?
just check that your heat riser valve is not stuck closed or has fallen off in the head pipe .yes it a long shot but have seen it happen.
I’ll give that a check tomorrow and see - it is worth checking for sure since it’s got a new electronic distributor that went in when I converted things to the HEI ignition. That and my vacuum pressure to the distributor from the carb.
Pick up leads in the distributor could be crossed. And cause symptoms very similar to this. Keep that in mind.
Nah, it's for sure not the distributor leads. Car won't even start when they're flipped and it starts/idles like a champ. Somehow managed to bust my timing light bulb in the old Sears timing light so the chase continues.
It may not start with the leads flipped from where you have them now because the initial timing is so far off. When you flip the leads you have to retime it. You will know right away when you get your light hooked up.
With the distributor leads flipped (wrong way) it is easy to time it and get it to run and idle just fine. When you accelerate the phasing (rotor to cap alignment) quickly goes out of whack and you loose time especially with vacuum advance. With the leads oriented correctly, you won’t loose phase. But you do have to re set the initial to see the difference.
An electric fuel pump isn't necessarily such a good idea; see here. The fuel pressure spec for the Slant-6 engine is 3 to 5 PSI, so 3.5 is right on target and plenty adequate.
As for fuel pump selection, see here and here.
Doesn't really sound like you have a fuel pump problem, though.
yeah definitely not a fuel issue. I got a new bulb for my timing gun and started the car up. no timing marks were visible during idle so the leads are definitely flipped.
