What about that fancy tile like the black and white? Is anything done there to seal the joints so spills don't get under it?
Sorry, must have fat fingered the phoneWhy would @tubbedamx disagree with an orry fat fingers asking with advice question?
All good, I was just wondering.Sorry, must have fat fingered the phone
Well that sucks!My shop just has the clear sealer on the concrete, that you roll on with a roller. It's hard to tell it's there these days because the shop was built in 2007. Plus it's full...lol. Downside to that type sealer is that if you spill gas on it, or lacquer thinner, it eats the sealer and makes a sticky spot.
I did sealer in part of my shop. The finish didn't hold up that well on the surface, but it did seem to seal the concrete. It seems like fluids don't soak in like it does with bare concrete. And it sweeps up better than bare concrete. So somewhat effective but not necessarily pretty if that's what you want.Well that sucks!
I had almost decided on just sealer.
Any type of sealer should do that. I'd just go for something that's got a separate catalyst. It's all in the prep.Don't want pretty, just want to keep spills under control.
Even on new concrete?Any type of sealer should do that. I'd just go for something that's got a separate catalyst. It's all in the prep.
Absolutely. Any product is going to want some type of acid etch prep to properly adhere. At least, the good ones will.Even on new concrete?
My Rustoleum floor lasted over 10 years with some serious abuse. It didn't peal except under the door from cold winters. I top coated it last year and it looked good until I started another restoration For the price I'll do that again when I'm done doing heavy work, painting, etc.I used some of the 2-part epoxy from Rustoleum with a coat of their 2-part epoxy clear (with anti-slip grit) on garage floor when I moved into my house in 2009. The parts near the garage doors that see sun have yellowed a little, but the rest looks good as new when it's clean. It does make wiping up spills a breeze and I'd do it again in a heart beat.
Where are you located? The reason I ask, the guy running the grinder looks a lot like my brother (gets grainy when I zoom in so I can’t tell for certain) who does commercial floor prep and epoxy floors.I have done two garages now. Several years back after completing construction of a detached garage I used a pricey two part epoxy. It was a total bust. The concrete had cured maybe six months when I put it down, maybe that wasn't long enough. Stuff started peeling up within a couple years and is pretty much all gone now. I followed the directions to a tee, but it didn't last.
A couple months ago I had our attached garage floor done by a company that came in, ground the surface off and put it down. This was some "new" to the market, polyaspartic I think it was called. Used on bridges and stuff (they say) and comes with a lifetime warranty. Supposed to be able to park a car with hot tires on it with no issues. It really does look nice, although as said in an earlier post - finding a screw or something dropped is near impossible! I watched several you tube videos to see if I wanted to do it myself - it would have been a big job doing it alone, and grinding the surface down - an acid etch doesn't take it down far enough. They also ground out a couple cracks and used a seam sealer to refill. They did a great job - and a whole lot different than the you tube videos I watched.
Rob, hit me up if you want the name of the company. I can't speak to long term yet obviously, but I am pretty confident that we are good to go here.
A few pics of before, during & after...
I live in middle Georgia, the company is out of Locust Grove, just south of Atlanta. They (there were two guys) seen my Duster, but they weren’t Mopar guys…Where are you located? The reason I ask, the guy running the grinder looks a lot like my brother (gets grainy when I zoom in so I can’t tell for certain) who does commercial floor prep and epoxy floors.
And my advice to anyone considering epoxy, I second what @cosgig said, don’t bother with the stuff from Lowe’s or hd, spend the money once and have a commercial company come in, grind the floor and use industrial epoxy, it’ll last WAY longer.
I gotcha. That’s not my brother then, he’s got a business named Tricor Floor Prep in Fort Worth, tx. Sure looks like him from a distance though!I live in middle Georgia, the company is out of Locust Grove, just south of Atlanta. They (there were two guys) seen my Duster, but they weren’t Mopar guys…
