Intake bolt
remytherat
Los Angeles
I have heard that sbm intakes can be swapped without pulling the distributor, but I cant figure out how to get the bolt loose in the back drivers side corner. I have a 9/16 dizzy wrench on it but can’t get any leverage. How is this usually done?
You can't get it with the box end of a combination wrench?
^^ This. Put a box end wrench on it and smack it with the palm of your hand. It's only 35 ft. lbs. You'll probably have to do that with the center bolts, too.
I don't think the guy owns a combination wrench.
That bolt holds the throttle bracket on my engine, which blocked the angle to get a wrench on it. Ended up pulling the dizzy which took 30 seconds
