In this case, it's a 5.9 Magnum.
I did that quite often as a youngster now its easy to mak emy back hurt. Anyway I lifted a bare 340 block a few years back onto an engine stand that was fun...and I agree with 160-175 lbs. Get heavier as you get older LOL!Not sure exactly, but I am still able to pick one up from the floor thankfully. I would guess around 175 lbs.
Just the bare block with main caps?In this case, it's a 5.9 Magnum.
I'd like to meet the two dudes that could toss a block 50 yards. lol It ain't happening.two middle aged reasonably fit men can pick one up off the ground and hoof it about 50 yards into the trunk of 70 dart with out being totally gassed, so i'd say about 170lbs
from where?!??Next question is how much weight can you trim off of one ?
Casting flashing , rough spots etcfrom where?!??
what's the over under on that? 2lb +/- 8oz?Casting flashing , rough spots etc
I don’t know . But some racers feel its worth it . There are even CNC programs for lightening blocks . It also makes them stronger in certain areas . Just a point of curiosity .what's the over under on that? 2lb +/- 8oz?
seems like a whole bunch of work for practically zero return.
No caps, not even the oil filter adapter. Completely bare, just the casting. Well the freeze and galley plugs are still there. I've cleaned up the casting a little, but can't be worth more than oz or two.Just the bare block with main caps?
