Stop in for a cup of coffee
Anybody watching Meecum in Kissimmee? Got home from the hospital and was up all night. 70 Duster 340 sold for 52k and a 71 twister sold for 37k. Didnt see the mill but a 3 speed manual.
Here they are...
seriously from the energy supplier!
Your monthly energy emissions report
Based on your monthly usage of 845 kWh for last month ending in 12/20/23 your energy emmisions value is 550 pounds of CO2.​
550 lbs.
CO2 Emissions​
550 lbs of CO2 emissions is the same as driving 622 miles in a gasoline-powered vehicle.​
4 trees would be needed to absorb 550 lbs of CO2​
So, do you cut these trees down and burn them or what?? Not following..well i am but lets not get into that
I'm at Midway Airport today, in the ride share staging lot... Go by the porta potties and the wheelchair accessible outhouse is blocked by a garbage can... There's no way someone in a wheel chair can get in there... :BangHead:
How the hell can these people run an airport safely if they can't even set up the bathroom station correctly in the parking lots??? :realcrazy:
It's not rocket science... :wtf:
Got some work done on plow truck, thermostat, wipers, replaced the trip spring that fell off the plow. So now its outside warming up while cooling off. If i start plowing right away, the snow will stick to the warm blade.
ai planning.
spray it with wd40
No doubt. One of those things that make you hake your head and wonder.
550 lbs.
CO2 Emissions​
