Stop in for a cup of coffee
Those were the days. (not my photo. I wish it was)
No, where the line comes out of the fuel pump.. it's the only flare i did and the only leak :) I did a single flare, doing a double and fixing that once it's not cold out again.. then i will add water and pray those head gaskets don't leak.. been reading bad **** bout them.. not a big job but a pain to setup the sideplay in the rockers in the car compared to on a stand... if i have to
Single flare on copper only. Double on steel line.tighten/loosen a couple times to seat it. Anti-sieze between nut and tube will help you in the future
yeah.. soon as it warms up i'm gonna practice doing double then make a new line again.. in the last few years cold weather just stops me dead..
Me too, i avoid playing outside when its cold. Shop is around 70f, i like it warm.
2.5 hours,1 panel made,2 welded in.so inside of cab corner is nearly 1/8 done…
yeah... my garage is decently warm but i dunno... when it's cold out i just go home and wanna hibernate.. soon as i go in the house i rarely come back out.
That's a stude? what's it gonna have for drivetrain? 360?
Its on 95 s-10 chassis, 2.2 4cyl, ps/pb/ac and cruise. It will weigh about the same as the s10. Im fine with low performance.
Same. I can sit up until midnight pontificating,and hit it in the morning with a poorly executed plan..
Essentially, the height difference between the heel and the ball of the foot is zero.
It rotates your pelvis to a more neutral position and aligns your knees and ankles.
Usually accompanied by a wider toe box so things like turf-toe and bunions are less impacted.
We do think alike, as I look down at my no heel flat shoe with wide toe box!
Smart guy to practice on a chunk of line.
I bought a hydraulic flaring tool. Makes three types. Made all lines on my 5th wheel. Converted from electric brakes to hydraulic disk. Works great. And it was not real expensive
yup.. trying to avoid buying a $100+ tool for 1 flare.. which between the cheap tool and wasted tubing would put me over 200... will figure it out :)
I can loan you my tool.
Naw.. if i can't get it with the current tool i will buy a good one.. i'm just cheap :) Never flared **** before so it's a learning thing... i don't know why i'm being so picky bout a line.. when i was 25 i woulda ran some rubber and said **** it.. now i'm all "Ohhh i want as little rubber as possible.... fire bad...." i'm weak..
