I was just outside with a jack on a board in the snow. I live it all the time.So, I assume no one considers me working under a big Tx. pine on the dirt is "high tech!??"
Yea, I have a floor jack and a sheet of plywood.![]()
SNOW. That is an ugly word here in Tx.!!!!!!!I was just outside with a jack on a board in the snow. I live it all the time.
I’ve been watching this one as well, and I’m about 90% certain I’m NOT going to spray foam the walls in my place next summer, but just go with fiberglass batts and call ‘er good. I can use the money saved on the spray foam elsewhere.I've been shoppin all around since this thread popped up and it seems like the most affordable insulation is the good old fiberglass batt insulation.
I worked in a metal shop that had the spray foam. Owner of the building was either cheap or maybe couldn't afford to line the shop after the spray foam. It was that way for years and it collected dust and grime. You couldn't do a thing without a trouble light. Place was very dark with the spray foamI’ve been watching this one as well, and I’m about 90% certain I’m NOT going to spray foam the walls in my place next summer, but just go with fiberglass batts and call ‘er good. I can use the money saved on the spray foam elsewhere.
In my previous two garages I installed 1/2" (nominal) OSB panels and then painted them white. In comparison to sheetrock, much less risk of punch something through it (bicycle handles, for instance), and much easier to mount storage accessories and what not. And the white finish just made the place all that brighter.The kraft paper on the batts kills the lights too. You need to put up Sheetrock or OSB and paint it white, either way.
Curious how this one turned out. What'd you end up going with?
That sounds like a good plan. You're doing the same on the ceiling, I'm assuming?I don't know what's up with this forum but it hasn't notified me on this thread in a long time. I thought it died out a while back and had no idea people were still posting in it.
It's real easy for people to just say spray foam it but it's not easy to cough up $15k for spray foam. I even attempted to see what the ceiling alone would cost and that was $7-8k depending on who I talked to. These videos on youtube where the guys got these massive 2000sq/ft shops spray foamed for $4k are full of **** unless they knew someone or got it done pre covid.
I'm doing 2" polyiso foam board with the reflective side spaced 3/4" off the siding. I found a guy who sells factory rejects for a reasonable price. I'm using great stuff spray foam with the applicator gun to seal up the seams and then using foil tape to cover. I'm only about 1/3 done at the moment.
Covering the walls is a pain because the studs aren't 16 on center. They're anywhere from 4.5-5.5ft apart and it's random. I wound up finding a guy on marketplace selling corrugated metal sheets for 1/3 what Home Depot charges. I'm going to cover the walls up to 8ft with that and then use CDX sheathing to cover above that. I'd rather do drywall but I'm not going to waste 1/3 of each drywall sheet because of the stud spacing issue.
Do you have any photos you can share?
That looks like it'll work nice. The air space seems like a good idea too. How are you attaching the foam and spacers?Right now that's the plan for the ceiling but it could change. I might leave the ceiling uncovered in case I need to add extra insulation. I'd like to test it out this summer and see how it feels. As long as it's not miserable then I should be alright.
I'd prefer to lay the sheets horizontally but I think the corners will look better if I hang them vertically.
I did the same as above. 30x40 shop, done with R30 batt in all walls and ceiling. Ceiling was covered in white tyvek-like material so it's real reflective for lighting. The walls were done 8' up in 1/2" plywood. Now that I have the mini split installed it's warm in the winter and cool in the summer. It's pretty posh for a guy that used to work in the driveway in the weather.I Have a 60x40 shop and my quote to spray foam was over $20k. no way that was gonna happen.
I have started doing rockwool batts, I like that I can do it in sections, and on my time, and not have to clean the whole shop out. It's frame with 2x8 lumber so I can use R30 rated batts, and then just put plywood/OSB panels over it and be done. Rockwool is great for a shop enviroment , doesn't absorb moisture and is fire retardant. In my research before starting it seemed to be the best option.
I am having the same issue with a building I put up last year. 25x30x14. Spray foam 5500. I am not spending that kind of money. I tried doing spray foam myself. Comes out too watery.Spray would be nice but I don't have 10k+ to spend on insulation.
