TT5.9mag
Two atmospheres are better than one
For now the only exterior paint work I’m going to do I already did. Just the tailgate amd wheels.That looks nice! Maybe some small blue pinstripes down the sides?
Probably long enough to realize you shouldn’t listen to me! Would be cool though, you’d just have to walk it out of the hole.Kidding or not, you’re kinda reading my mind. Don’t think I haven’t considered slipping the TTW2 motor in there just for ***** and grins cause I have. I wonder how long the 8-1/4 diff would hold up to 10psi clutch dumps?
That’s a long crank, at least it would be easier on it than a supercharger.Naw. They'll take it. Least the forged ones.
Screw it. 20PSI or bust. lolProbably long enough to realize you shouldn’t listen to me! Would be cool though, you’d just have to walk it out of the hole.
It'll be fine. Traction will be the weakest linkKidding or not, you’re kinda reading my mind. Don’t think I haven’t considered slipping the TTW2 motor in there just for ***** and grins cause I have. I wonder how long the 8-1/4 diff would hold up to 10psi clutch dumps?
But if it ever did hook and load the turbos you can kiss that diff goodbye.It'll be fine. Traction will be the weakest link
i had 8 months.Go back and read post 1. I bought this truck in November and my asshole friends were taking bets on how long the slant 6 would last. Whoever took the under on that bet gets a cookie.
What the ......In your best Don McLean voice,
“And we were singin, bye bye mis American pie”
Carb.Are you running a carb on the magnum or efi?
I did.i had 8 months.
who had the under?
sand bagger!I did.
Listen mr funny man, you know me too well and also not at all. We stood there and talked about how easy it would be to put a couple snails on it. And I even have magnum turbo headers I built years ago. But this one will (probably) not get boost. For now.When the turbos going on?![]()
i technically had 8mo till you "really" put a motor in, and for you does it really count if it doesn't have turbos on it?Listen mr funny man, you know me too well and also not at all. We stood there and talked about how easy it would be to put a couple snails on it. And I even have magnum turbo headers I built years ago. But this one will (probably) not get boost. For now.
Wow you guys are really on me. I thought for sure a nitrous small block crate engine would be enough. Apparently not. I’m trying to keep this one simple. Mechanical fuel pump, mechanical fan, no fancy electronics (except the trans controller) and just a nice reliable driver. Does everything need 900hp? Don’t answer, I knew as soon as I asked. I’ll bring you some butter cookies (homemade of course, no Vons store bought stuff here) to the fling.i technically had 8mo till you "really" put a motor in, and for you does it really count if it doesn't have turbos on it?
so i still technically have another 4mo in which you will probably turbo it and deliver said cookies unto me.
i like vons butter cookies, you know i'm low rent like that. i'll mark my calendar.
Don’t fight it, just embrace who you are!i technically had 8mo till you "really" put a motor in, and for you does it really count if it doesn't have turbos on it?
Lmao I did! I put nitrous on it!Don’t fight it, just embrace who you are!
That’s pretty close, however I see turbos in your future. I think either way it’s gonna be pretty cool! Still digging the look!Lmao I did! I put nitrous on it!
